My new Dell computer has a CD-ROM/DVD: TSSTcorp DVD+-RW TS-H653B.
What I need to know, since I am such a newbie when it comes to DVDs and such, is if I can use either DVD - or DVD + to burn for my stand alone DVD player connected to my television?
That appears to be this Samsung SATA writer: https://www.videohelp.com/dvdwriters/samsung-sh-s203b-ts-h653b/2089
If so, yes it will write to + or - media. Of course the brand of DVD media may determine the results. Use a good brand and you should have no problems most times.
And your player is also part of this. It may depend on what brand and type of media it likes best.
You can look up both your burner and probably your player, and different DVD media brands, along with some user comments about media for each to the left in DVD Writers, DVD Players and DVD Media. <<<<<<
And welcome to our forums.
Thank you for the welcome.
What media would you suggest for burning DVDs and such? I use and like Sony CD-Rs. Of course I have never used this burner with them yet but it plays what I had burned before with my music CDs and data CDs. -
I usually recommend Verbatim or Taiyo Yuden brand media. But Sony DVDs seem popular, also.
For comprehensive DVD meda info, try: http://nomorecoasters.com/
EDIT: ofbarea was quicker.
One thing to note is that DELL has a habit of using their own firmware and in the case of the LG drives they've used in the past the drives functionality is usually crippled.Originally Posted by redwudz
The drive can be crossflashed to the SAMSUNG firmware but as always it would void the warranty with DELL.Originally Posted by MysticE
Media Express 3.0.3 Question?
By Darkensteele in forum Capturing and VCRReplies: 0Last Post: 27th Dec 2011, 04:47 -
Media Player Question
By gazbag in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Jan 2011, 09:54 -
First time using HD media question.
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Dec 2010, 08:34 -
question re wd hd media player
By julie_152 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Sep 2009, 11:46 -
FAQ didn't answer my question. What's the best DVD-R 9GB media to buy?
By insomnia976 in forum MediaReplies: 7Last Post: 18th Jul 2009, 13:10
