    Nov 2007
    I'm looking to edit some old VHS tapes that I made when I was a kid.
    How the hell do I get them into FCP?
    Nov 2007
    OK I know, read would ya?
    So I did some research and found that all I have to do is...
    1. Convert the VHS to DVD via my Sony video converter
    (that I picked up at Best Buy new for only $150)
    2. Purchase and download DVDxDV
    3. Insert DVD and extract whatever clips I want or the entire DVD into .Mov
    4. Edit away.
    If you use something like DVD FAB, or DVD Back Up as well
    you can even edit clips from any DVD, including Major studio releases.
    (I wouldnt unless you like lawsuites).
    Man, Terryj will be so proud of me.
  3. Member terryj's Avatar
    N35°25.24068, W097°34.204
    LOL!!
    Xmas came early for me this year.....
    JAMES, any further questions don't hesitate to post.
    Also, don't kick yourself, but if your camcorder
    has analog I/O, you could have ran your vcr into
    camcorder, played the VHS tape, set the Camcorder
    to passthrough, and imported the VHS directly into
    FCP as a DV Stream.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Nov 2007
    I'm new to this stuff, yet I've always wanted to be in this field. What you get
    is someone who wants to learn everything in one month. Now I know it's almost
    impossible, but I'm doing my best to get it done.
    Thanks for your help, and for your patience with me.
  5. Member danielheldman's Avatar
    Dec 2007
    it is 320X240, very poor picture quality.
  6. Member terryj's Avatar
    James,no prob.
    @daniel:what R u talking about?
    Urban Mac User
    Apr 2007
    Australia
    Get a tv card w/ composite inputs and audio inputs (if none there, use the line in input), plug the VCR in using the correct av cables. Open up your tuner software. Check that everything is working, then press record on your tv card software and then press play on the vcr. It works for me!
    http://www.pcpodcast.org (Website Under Construction)
