Hi everyone. I mentioned in another post that I use vob blanker to replace titles in dvd's. I have a slight problem with that. I also have dvd's which have multi angle that Vob blanker can't handle. So since i want to process these vts's that are multi angle, I found that you can do a similar thing with pgcedit. I click on "Replace VTST Titles" and try to import titles but the only problem i am having is that, for example i want to replace titles in VTST 4 but I can't seem to do 1 title at once, It seems I have to do all the titles in the VTST. And that, i have no problem with. So I took all the titles i wanted to be in the VTST and reauthored them with dvd shrink but It still says that the number of TTN's don't match when I try to import the titles. How can I create a reauthored DVD Titleset that recognizes 5 TTNs in the set instead of just one?
Hi-
Short answer - you don't.How can I create a reauthored DVD Titleset that recognizes 5 TTNs in the set instead of just one?
You can strip out all the angles but one and work with just that one, or about the only program that can handle multi-angles is the Pro version of DVD-Rebuilder.
Change frame rate. Audio don't match with Video...?!
By SB4 in forum Video ConversionReplies: 2Last Post: 25th May 2011, 15:55 -
Possible to Photomerge Style Match in CS5? A feature that is in Elements 9
By Denvers Dawgs in forum ComputerReplies: 0Last Post: 8th Jan 2011, 15:06 -
Edit & Replace DVD menu with PGCEDIT?
By kpic in forum Authoring (DVD)Replies: 1Last Post: 27th May 2010, 17:40 -
Is this possible? Replacing titles with PGCEDIT after authoring
By kpic in forum Authoring (DVD)Replies: 4Last Post: 6th Feb 2010, 12:18 -
Feature request - auto titles
By Neil Herber in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 8th May 2008, 13:49
