Hi everyone. I'm not ecactly a newbie because I have been editing DVD's for a while. I use a lot of different programs to achieve the results I look for. Right now I am having issues and something has me stumped and I can't find help anywhere so I hope some of the masters out there can help me. I used to use vob blanker to split my dvd 9's onto 2 DVD 5's and keeping the same menus. The dvd's I am working on are episodic DVD's. Now that Double layers are cheaper, I am redoing some of them using VOB blanker's replace feature and pgcedit's fix pre commands/post commands feature. I had success with one particular DVD. So what I did was take Part one of the DVD and use vob blanker's replace feature to put back titles 3 and 4 where they originally were and output the file. Then I opened pgc edit and changed the pre commands back into post commands for titles 3 and 4 and saved it and it worked wonderfully. So I then tried to do another dvd the same way. This DVD has 5 main titles and titles 4 and 5 had been blanked out. So i did the same thing with this dvd as the last one and tried to play it and I came to find that the audio for the titles I had put back in will not play. I did some research and found that when I go to pgc edit under Info - Streams VTS 4 only lists the first 3 audio streams and does not recognize the last 2 I edited back in. I checked the first DVD I processed and It has 4 listed So i guess this is why it worked ok. I have tried everything I can think of to get this DVD to work but I am stuck. I need to know How to properly edit the VTS 4 of this dvd to recognize 5 audio streams instead of just the three it had when the first part was blanked out. Can anyone recommend a solution to this pickle? Thank you in advance!
never mind about this i figured it out. Somehow, it seems that the first dvd I did all the audio streams were enabled but the second one the last 2 were disabled. I clicked on "edit pgc" and enabled the audio streams. Any help you guys could give me on pgc edit would be appreciated. I am still figuring out how to use it!
DVD split with DVDFab. Movies don't run smoothly, goes back to first scene
By whenloverageswild in forum DVD RippingReplies: 1Last Post: 15th Jul 2009, 14:16 -
Can't find still in dvd with pgcedit or vobblanker
By CuriousYellow in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2009, 02:56 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
vob blanker took away 'skip' feature
By m-man in forum Newbie / General discussionsReplies: 0Last Post: 15th Feb 2008, 00:07 -
titleset blanker w vob 'viewer' ?
By gazix in forum EditingReplies: 4Last Post: 2nd Aug 2007, 13:19
