I'm looking for a photo printer and scanner in one. I currently have an epson r200 and have no problems with printing quality, so I was looking at the epson CX8400. My real question is about the scanner portion. What should I be looking for for a resolution. The CX8400 scans @1200x1200 resolution. The scanner would be used for docs as well as photos if needed. Is 1200x1200 good for photos?
What We Do In Life, Echoes In Eternity....
1200 X 1200DPI scan rate is overkill most times, IMO. I do 90% of my photo scans at 300DPI. Higher rates will take forever on a large photo and you are not likely to see much difference unless your photo is an inch or two square.
I've used several HP all-in-ones that have a printer, scanner, copy capability, print photos from a SD card and also fax and have network connection capability and no problems with any of them. The only downside is some have tiny ink cartridges, especially the ones with six cartridges. Be ready to replace them fairly often if you do a lot of photos.
The price of cartridges and how much they will print is a big issue. There are many economy printers that sell for about $30US, but the inkjet cartridges cost more than $50 each.Walgreens Drugs, for one, sells refilled cartridges fairly cheap. I refill the black ink ones myself. The color ones are a bit trickier as you need to calibrate the printer as the colors seldom match the OEM cartridges exactly.
Originally Posted by redwudz
Originally Posted by Denvers dawgs
Personally, I scan small b/w prints that I want to touch up and later publish, I scan slides, I scan negatives. These can only be done on a 'photo' quality scanner. I got the Epson Perfection 4490. Resolution of 4800dpi if I want it, and necessary if I'm going to scan a itsy-bitsy neg, transpanrency head etc. You can get these scanners second hand on e-bay (especially if you are in the US) for dirt cheap. There's the Epson Perfection 4490, 4890, 4990 all similar capability. I got mine second hand from e-bay and its worth every cent.
Indoor antenna recomendation please
By Zetti in forum Capturing and VCRReplies: 23Last Post: 4th Sep 2011, 20:01 -
Epson p50 photo printer compatable cartridges
By Rogert in forum ComputerReplies: 0Last Post: 4th Aug 2011, 07:46 -
My HP printer D5360 died, looking for a new DVD printer
By stiltman in forum MediaReplies: 9Last Post: 18th Mar 2011, 23:04 -
Seeking editing software recomendation
By username_5 in forum Newbie / General discussionsReplies: 9Last Post: 17th Jan 2011, 10:06 -
:?: Authoring software recomendation/encodes multiple formats
By pgwerner in forum MacReplies: 3Last Post: 29th Dec 2008, 14:13
