I downloaded an OpenDivX4 avi movie and it has an frame rate 24.975 which is near the Pal 25 but a resolution the same as NTSC DVD / SVCD. I am in region 1 NTSC.
When I try to play with VLC I get a message AVI file is broken Seeking will not work correctly. Do you want to try to repair it (may take a long time) I click no and it plays fine. It also plays with WMP, Nero ShowTime and Winamp.
Q1 Should I try to have VLC fix it? Q2 - Should I keep it as it is or should I convert it to another avi ? Q3 If I want to convert and burn as a SVCD or a DVD, what should I do?
Open for any suggestions.
Thank you, Joey
It appears that subs are hard coded.
From GSpot
File Size............ 1,029,176,424 bytes
--- Video Information ---
Video Codec Name..... DivX 4 (OpenDivX)
Duration............. 1:42:30
Video Bitrate........ 1198kb/s
Bits / Pixel......... 0.139
Resolution........... 720x480
Aspect Ratio......... 1.500
Frames Per Second.... 24.975
--- Advanced ---
B-VOP................
N-VOP................
QPel.................
GMC..................
--- Audio Information ---
No of Audio Streams.. 1
Audio Codec.......... 0x0055 MPEG-1 Layer 3
Audio Bitrate........ 128kb/s CBR 48000 Hz
Audio Channel Count.. 2
ÿ
Hi-
There's nothing wrong with a framerate of 24.975fps. That's what you get when you unblend an NTSC DVD originally from a PAL source made using a PAL master. The framerate has nothing to do with your problem.
If it plays fine I don't see any need to either "fix" it or reencode it because of the VLC message. No, if I were to reencode it it would be because of the reported 720x480 framerate. Unless you already know that gives a bad AR and are using a player to resize it. Me, I much prefer to make my AVIs 1:1.
If you want to convert it to DVD or SVCD, reencode it for 25fps keeping the same resolution (and 4:3 or 16:9, depending on whatever it's supposed to be), and when all done, run the resulting MPV through DGPulldown with the Custom Box checked and 24.975->29.97fps filled in. That way you don't have to stretch the audio. It'll remain in synch. Just convert the MP3 audio to AC3.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Newbie : How to convert PAL into NTSC Format for Video Cassette Player
By kato2010 in forum Newbie / General discussionsReplies: 7Last Post: 11th Sep 2010, 11:40 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 20:15 -
Help. Convert menu sublayer from 720x576 to 720x480 (PAL to NTSC)
By danfisherman in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2009, 12:56 -
Bad NTSC to PAL converstion - jerkiness. How to fix?
By PTRACER in forum Video ConversionReplies: 34Last Post: 11th Sep 2007, 18:00
