I heard it was in the registries... but me and registries don't mix well.
What kind of delay? What mode?
http://www.kiva.org/about -
I dunno, I just got this card a couple days ago. If I hook this up to a console, because of the hardware recording (which is an awesome feature) it delays the button presses on the console game significantly. I heard you could reduce this delay by editting the registries.
Delay is present in all encoders and all computers. To record gameplay, you split the output from the console to the TV and computer (recorder) and watch the TV.Originally Posted by RoganSarineRecommends: Kiva.org - Loans that change lives.
Yes, but not to the point where you can play a game using it. edDV is correct - you need to split the TV signal out to a TV.Originally Posted by RoganSarine
/Mats -
http://www.cask-of-amontillado.com/htpc.html
Go to the "Tips and Tricks" section, enable Live Preview.
It works for the 350 and 250. Not sure about the 150. I suspect you'll have to manually search for the "LivePreview" key rather than use the REG files the site provides. There will still be a little lag, but not the usual 1 or 2 seconds. -
Note that the 150 card has a completely different chip set from the 250 and 350 models, so jagabo's tip may not work, and he suggests this possibility. It's worth a shot, but since he may not know that the 150 uses a different chip set, I thought it was worth mentioning.
I'm pretty sure the tip at Amontillado's site does not effect the hardware -- it effects the WinTV2000 software. It just tells WinTV2000 not to buffer up a few seconds of video before displaying it.
Even so, I think the actual location of the flags in the registry changes from version to version so he will likely have to find the registry key himself.
HD DVR cable>Happauge HD PVR> crashes my PC
By edong in forum ComputerReplies: 3Last Post: 8th May 2011, 17:42 -
Happauge WinTV-PVR 500/1600 Streaming
By valis77 in forum Capturing and VCRReplies: 1Last Post: 1st Mar 2011, 23:47 -
Happauge WinTV-PVR 500/1600 Streaming Dual tunner
By valis77 in forum Capturing and VCRReplies: 0Last Post: 1st Mar 2011, 23:41 -
Happauge HD PVR?
By neworldman in forum Capturing and VCRReplies: 5Last Post: 12th Apr 2010, 22:00 -
Bitrate problem - PVR-150
By m0dts in forum LinuxReplies: 4Last Post: 14th Dec 2009, 14:47
