Hi guys, I recently bought a Canopus ADVC110, and while it's great for my PAL stuff, whenever I try to anything other than that I get a picture roll. This is the same whether I try it with S-Video or Composite connections. Also, the audio tends to crackle when this happens.
I have tried to capture footage from an American Sega Dreamcast game. I've captured footage to show what the problem is. The first part of the video is the capture with the ADVC110 set to Pal, and half-way through I flick the switch underneath the grabber to NTSC. As you can see, I get sound (albeit crackly sound) and the picture roll gets worse:
http://video.google.co.uk/videoplay?docid=2993165879711884421&hl=en-GB
I then tried with a UK GameCube game set to 60hz mode and the same problem occurs.
Is there an easy way to fix this, guys? I've tried every possible combination with the switches underneath, and this happens a lot when I try to capture any NTSC stuff, or try to capture PAL games in 60hz mode. I don't want to have to buy yet another grabber, because this one was pretty expensive for me and I bought it under the impression it could capture PAL, NTSC and SECAM footage flawlessly.
			Closed Thread
	scully1888, Do not post the same topic on several forums.
 Please do not cross post, once is enough.
 Continue in https://forum.videohelp.com/topic342274.html#1787191
 Moderator redwudz
  "Live" picture effect - pictures end up "filmized"By ANOther1676 in forum Software PlayingReplies: 10Last Post: 14th Oct 2011, 12:59
  Questions Regarding Video Capturing for "Gameplay" VidsBy cdubya in forum Newbie / General discussionsReplies: 3Last Post: 18th Jul 2010, 19:26
  DVD with menus, replacing "bad" video with "good" videoBy chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45
  Picture "rolls" when trying to grab 60hz footageBy scully1888 in forum Capturing and VCRReplies: 4Last Post: 21st Dec 2007, 05:41
  Video is "blocky" when capturing DV via firewireBy kongla in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 29th Jun 2007, 04:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
