Hi there.
I need to join 3 .ac3 files into one.
All of the .ac3 files are 0ms delay so i think they have no errors i think![]()
Can someone tell me how to join this 3 .ac3 files into a single .ac3 file???
I use windows Vista so BeSweet doenst work.
Results 1 to 10 of 10
The following works for me
type: copy /b file1.ac3+file2.ac3+file3.ac3 finalfilename.ac3 -
Nope, from the COmmand prompt, see https://forum.videohelp.com/topic336552.html#1750284 for an example how to use it.
Originally Posted by Baldrick
Thanks both of you i am going to try it and then i tell the results -
Dos did it alone
That was cool fast and easy
Thanks ( i hope it did change the time line) -
X_Splinter escreveu:
Dos did it alone
Originally Posted by X_Splinter
"In order to fix a corrupted audio stream, simply drag it onto BeSliced window, and click on 'Fix File!'. On finish, BeSliced will pop-up a logfile that lists all errors that was detected in file."
Join AC3 files
By rgraiche in forum AudioReplies: 8Last Post: 20th Aug 2011, 15:56 -
Split, join, create silence of an ac3 file
By phate89 in forum AudioReplies: 6Last Post: 16th Jul 2011, 13:34 -
How Do I Join M2V and AC3 Files?
By lovelylisa in forum Video ConversionReplies: 1Last Post: 6th Jun 2011, 17:13 -
Join .MP4 with .AC3 to .MKV without loss of sync
By vanleeuwen in forum Video ConversionReplies: 2Last Post: 18th Dec 2008, 02:53 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
