i just got this sony mini dv camcorder ,when i capture using its firewire in vcd mode,the quality is so low,it has no difference from when i capture from my vhs tapes ,sometimes capturing from my vhs tapes have a higer quality than my camcorder,what should i do? i am using pinnacle av dv ,i expect capture from a minidv camcorder to be higher than capture from vhs tapes or s - video or composte sources,please advice.
Results 1 to 14 of 14
VCD Mode? VCD = Crap, so I wouldn't use any VCD mode.
Can't you choose to just capture/copy the dv stream to your hdd in pinnacle av dv? Or use WinDV to copy the DV to an DV-AVI that you then can edit and convert to any format using most tools.
And this is DV so moving you to our DV section. -
I agree with baldrick.. Capture as DV-AVI, make any editing changes you desire, then encode at between 8000 and 9000 or select highest or best quality setting for your encoding.
Rob -
some of my clients request vcd format for job,i captured in avi format but when i renedered to vcd ,the quality dropped
click the vcd button up in the left under 'what is" for the specs. it isn't good for anything and you're right it's as bad as vhs. at 1150kbps any motion will be blurred.
i have seen some local hoem videos and the quality of the vcd is awesome ,if i was using an hdv camera would that give me a better vcd result or perharps i need to buy or use a higher editing card ,which will propbably help ?
VCD and awesome in the same sentence - did you keep a straight face when you typed this ?i have seen some local hoem videos and the quality of the vcd is awesome
A better camera will not give you better quality from a low resolution, low bitrate format. The videos my phone shoots give VCD a run for it's money - that's just how it is.Read my blog here.
tunde, not sure what your problem is....one place you say you "captured in VCD mode" then you say you captured in avi!?!?!? Which is it? What codec is the avi in when captured (actually, should be "transferred" as said above)? Use gspot to find out codec.
IF it's a fairly short video he should get OK quality VCD, right guys? If not, why? Isn't it just a capacity issue vs. DVD?
Try any other encoding software? maybe a better one is out there for your needs. -
The low bitrate used in VCD will give better results with low noise and low motion sources. So handheld footage from a cheap camcorder will give poor results. A high end, low noise camcorder on a tripod will do much better.
Transferring first into lossless DV-AVI and then using a quality MPEG encoder at VCD spec may help. What encoder does Pinnacle use?
The undeniable fact is that VCD is a low quality format that only gained popularity in certain places and serves no legitimate purpose in today's world. I understand you're trying to give people something they've requested but maybe you should try and talk them into a more current format. -
Show the client the difference between DV.AVI to DVD MPeg2 and DV.AVI to VCD. They may change their mind.
http://www.kiva.org/about
Using Sony HDR-FX1 to Capture a Mini-DV @ 24 FPS
By foochuck in forum Capturing and VCRReplies: 3Last Post: 11th May 2011, 18:50 -
Import from mini DVD on Sony Handycam camcorder
By usctrojan98 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd May 2009, 14:53 -
Capture analog video from sony camcorder
By gthoman in forum Capturing and VCRReplies: 14Last Post: 14th Apr 2009, 15:32 -
Sony camcorder mini-dvd help
By videochallenged in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2008, 11:06 -
Broken Sony Mini DV Camcorder/Now how do I play?
By brokendc10 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2008, 13:30
