Whenever I try to capture video from DVD to my ATI TV Wonder VE.... I get wierd horizonal color lines that are spaced every cm in length down the picture screen.
I can capture video from a VCR without problems.
What is this caused by and how do I fix it?
DVD uses Macrovisioned signal and you will get distortion when you try to capture it. Go to http://stinky.dosrules.com/ to download MMC7.5 Reg Tool. Within it, you will find a zip file Disabling ATI Macrovision Dection. You may follow the direction and give it a try. I have not though...
Black horizontal lines when capturing
By cyanure in forum Capturing and VCRReplies: 3Last Post: 14th Aug 2010, 08:09 -
Horizontal black lines in exported HD video
By progressive_pete in forum Video ConversionReplies: 5Last Post: 25th Jan 2010, 07:36 -
Bright horizontal random lines in 8 mm Camcorder Video
By axhack in forum RestorationReplies: 4Last Post: 11th Jan 2008, 21:05 -
Horizontal Lines making video unbearable
By Fatalize in forum Capturing and VCRReplies: 5Last Post: 20th Sep 2007, 12:27 -
Horizontal lines on video playback with vista
By richard.fisher in forum Software PlayingReplies: 7Last Post: 4th Jun 2007, 08:48
