In ffdshow, if I want to crop a video I can press CTRL, ALT, C to do it...how can I disable either one OR both of the activation keys CTRL and ALT, and just set it to work with pressing C (or CTRL C or ALT C)?
The reason I want to do this is so I can use this feature with my ATI Remote Wonder Plus, but it isn't working when I set up the full macro. Please tell me how I can do this task? Someone said I could remove something from the registry, but I have no idea what that means or how to do it.
I'm actually 3 years old, so please be very detailed and clear. Thank you!
Weltall900@yahoo.com
Results 1 to 1 of 1
KMPlayer and FFDShow deinterlace - how to get "bob" effect working?
By ANOther1676 in forum Software PlayingReplies: 3Last Post: 18th Feb 2011, 08:47 -
How to disable MPC "could not render some of the pins in the graph" warnng?
By SignedupGuest in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2011, 23:50 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
ffdshow and haali, "recommended" version control
By tbone8 in forum Blu-ray RippingReplies: 1Last Post: 12th May 2010, 22:55 -
API "SetParent" in VB6: Function & Ctrl keys don't work
By gll99 in forum ProgrammingReplies: 4Last Post: 9th Mar 2008, 20:37
