  1. Member WinSpirit's Avatar
    Computers room
    Please help !
    The Mainconcept DV Codec v2.4.6 seems to be installed correctly on my system ( using GSpot to verify ), but it doesn't appear in virtualdubmod's compression list since a few days...
    absolutely Need it !
    Tried to Deinstall/re-install many times, with no success.
    Yet, I used it with vdubmod in the past with no problems.
    Any suggestion ???
    TIA
  2. Member WinSpirit's Avatar
    Computers room
    I found why
    A key in the registry was overwritted during the installation of Canopus Procoder:
    [HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Drivers32]
    "vidc.dvsd"="hldvsd.dll"
    The correct value is:
    "vidc.dvsd"="MCDVD_32.DLL"
    Shine as you should !
