Results 1 to 9 of 9
    Dec 2007
    heres what the note says when i try to upload my mpeg into windows movie maker
    The file C:\Documents and Settings\Paul\My Documents\My Videos\Ease Springs Bar Fly mpeg.mpg cannot be imported because the codec required to play the file is not installed on your computer. If you have already tried to download and install the codec, close and restart Windows Movie Maker, and then try to import the file again.
    any suggestions please
    thanks
  2. Banned
    Jun 2007
    UNREACHABLE
    Install ffdshow
    USA
    Windows OS doesn't come with a MPEG-2 codec, so you would need to add one. This is apparently because of licensing. It does have a MPEG-1 codec, used for VCDs most often.
    ffdshow is one way to install it or you can add just a MPEG-2 codec or install a player like PowerDVD or similar that includes the codec. Some versions of Vista do have the MPEG-2 codec included.
    Dec 2007
    thankyou very much guys ill try the ffdshow first
    Dec 2007
    just out of interest the mpeg file i have is from vob2mpeg what mpeg would that be please?
    Dec 2007
    plus its asking mt what files i should select ffdshoe to decode and the mpegs arent ticked
    Dec 2007
    ive ticked mpeg 1 and mpeg 2 aswell as the ones it was suggesting
    Dec 2007
    ive unistalled the ffdshoe codec as it only gave me audio
  9. Mod Neophyte redwudz's Avatar
    USA
    booyaka, I know you are new here, but you can edit your existing posts and add new comments without starting a new post for each thought. We try not to clutter our forum up with more posts than needed to convey the ideas.
    And if you only need the MPEG-2 codec for WMP, try Stinkys MPEG2 Codec. It works fine with WMP. If it doesn't work, then you have other problems.
    But check your file first with Gspot 2.70 and see what codec it requires.
    Moderator redwudz
