Results 1 to 9 of 9
  1. Is there anyway to break the FAT 32 limit of 4gigs without upgrading to Windows 2000? Maybe a hack for the win98 kernal? a software patch... something. Getting only 15 mins of video sucks and i dont want to shell out $200 for Windows 2000.
    Im using:
    AMD Duron 800
    Asus 630/730 video
    ATI All in Wonder VE
    112 MB RAM
    30 Gig HD
    ATI Multi Media Center 7.1
    Windows 98
  2. Virtual Dub and AVI_IO both allow for segmented captures (you can set the size of file segment, I normally use 1.9GB). Click on the 'Faq' to the left, and look for enable Virtual Dub spill system/multi-segment captures.
  3. dude, i am up the same river as you. i have been trying to find a way to do it with WinME but i have come up empty handed. i have read a little about converting the drive to NTSF but i havn't been able to confirm anything........
  4. Originally Posted by alucard2050
    You can only run a ntfs file system if you use NT,2000 or XP cant be done on ME 95 98 98SE
  5. i figured as much but i am still hopefull to find a way around it............
    Jul 2001
    Maryland
    it is impossible in fat 32
  7. actually, you can convert the win9x/me fat32 file system to ntfs with a program called "win9x to ntfs", you can get the program from www.apachez.net.. it worked pretty good for me.. i'm using win xp pro now though, so it doesnt really matter anymore. good luck tho
  8. Just capture less than 4 gigs and encode using tmpgenc and merge them together. that's what i do and it works fine.
  9. You cant break the 4gb limit in Windows 9x or me. What you can do is either switch to a differnt OS or use a program that supports multi segment capture.
    I don't think the NTFS driver for windows 9x will allow you to go over 4gb.
