I've got an FLV file that, for some reason, won't convert into anything else. It plays fine on its own, but I can't use FFMPEGX to change it into an AVI. Has this happened with anyone else? If so, what can I do about it?
Results 1 to 10 of 10
have you tried Quicktime Pro with Perian 1.0 installed?
will it play in Quicktime Player with Perian 1.0 installed?
Have you also tried VisualHub?"Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Perian is free.
What software do you have besides, I rightfully assume,
a paid for version of ffmpegx? Do you have MpegStreamclip
(also free)? Have you tried it? and with Perian installed,
if it plays in Quicktime Player, you can troubleshoot
what it might be getting hung up on (necessary codecs
for the audio perhaps?)
Lastly, how bad do you want the file in AVI format?
everything costs, whether time for effort or software...."Everyone has to learn, so that they can one day teach."
Urban Mac User -
Yes, I tried adding Perian and the movie still won't play in QuickTime.
I have the freeware version of FFMPEGX, and also MPEGStreamclip, neither of which will have anything to do with this one. FFMPEGX converts plenty of other FLV files, but there's just something about this one...
I am trying to assemble a slide show from YouTube clips, but my software (iMovieHD, After Effects) won't take FLV files.[/i] -
Have you tried flvextract to split the audio and video. Then you can convert them separately whatever part is the issue.
Or maybe your flv file is a vp6/flv4. You may have to install ffdshow and make sure both (H.263/FLV1 and VP6/FLV4) are checked on so they are decoded by ffdshow in order to convert it. -
Urban Mac User -
Originally Posted by ker-plop
Originally Posted by gll99
I had to stream rip some FLVs from a site, convert to an edit-able format, and then incorporate into frames with commentary, and edit to a DVD that could be played. Buying Parallels and installing already-owned copy of Windows, using Windows freeware or already-owned Windows software, was cheaper than paying for random Apple software that doesn't seem to cut the mustard.
Just my take on things.
Make these systems work together, don't isolate yourself to just using one.
If you have a CompUSA near you, some of the software is on clearance too, and that's where I got Parallels. Amazing to me was that Windows boots faster in Parallels than it does using BootCamp, and it works perfectly fine. Faster than one of my desktops, in fact, because the MacBook has a really good Intel Core 2 Duo and 2GB RAM. Plenty of resources. Did a static 4.35GB virtual drive for OS (easy backup to a SL DVD), and a dynamic hard drive for the encoded work (shrink back down when needed, using Parallels utility). You can also share folders, but it didn't seem to like encoding to a OS X share, not sure why.Want my help? Ask here! (not via PM!)
How to convert FLV videos and resize them to convert them to AVI
By zikegi in forum Video ConversionReplies: 2Last Post: 17th Sep 2011, 23:06 -
Winavi won't convert flv's to dvd ...
By AshleyQuick in forum Authoring (DVD)Replies: 2Last Post: 5th Sep 2011, 14:50 -
which software works best for flv to dvd can i convert dvdor flv to divx
By rugrat23 in forum Video ConversionReplies: 2Last Post: 19th Jan 2011, 12:39 -
VirtualDub Won't read FLV Files
By Markgc in forum EditingReplies: 24Last Post: 20th Nov 2009, 19:25 -
Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVI
By videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 00:14
