Hi all,
I've been having success capturing VHS tapes to MPEG2 using MainConcept Capture software - however I have a couple of questions that I can't find the answers for:
1. ColorSpace - the capture card(s) that I use can capture in YUY2 or RGB24 - I was led to believe that MainConcept always works in RGB24 - does this mean if I am capturing directly to MPEG2 and I select YUY2 colorspace that MC will convert to RGB24 on the fly? Loss of quality?
2. Profiles - I can use the 4:2:2 Profile or the Main Profile 4:2:0
I know that the file size will be a little bigger using 4:2:2 - and when I demuxed to .m2v and .mp2 using either ProjectX or DGIndex the file size does get reduced
I then convert the .mp2 to wave then to .ac3 (believing that NTSC DVD's have to have .ac3 - is this the case?) then I use either Muxman or DVDAuthor to create the DVD files for burning . . .
My question here is:
am I getting any better quality by capturing in 4:2:2 profile which after demuxing turns into 4:2:0 or will I get the exact same quality just by capturing using the Main Profile 4:2:0
Any suggestions are appreciated. TIA
Results 1 to 1 of 1
How can I convert MKV profile high@5.1 to MKV profile 4.1 ?
By utahmar in forum Video ConversionReplies: 53Last Post: 4th Nov 2012, 08:03 -
Low profile capture card options
By GLE3 in forum Capturing and VCRReplies: 7Last Post: 30th Mar 2010, 17:59 -
How can I convert MKV profile 5.1 to MKV profile 4.1 ?
By Sanshero in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 03:40 -
By Sanshero in forum Video Streaming DownloadingReplies: 1Last Post: 26th Mar 2009, 12:32 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56
