I recently re-did my system for better performance. Still on XP pro. This program will nt activate for some reason. Have installed the newest version. Everytime I try to open it it takes me through putting user name and reg number in. I hit next to get my activation key. Then I hit activate. Sits there for a couple of seconds then the programs splash screen comes up. The splash screen goes away but no program it just closes. Please help.
-Del
Hi Del - drop me an email and we'll do it manually. Couple of questions first: XP or Vista? Is SVCD2DVD installed on your system partition?
I figured it out and emailed you about it chris. I have 2 partitions on my main drive. A small one for the OS and a huge one for all my programs and stuff. After the reinstall of XP I ran SVCD2DVD setup as I normaly do. This put it back in the folder I had it before but for some reason created a subfolder. That was the problem.
I had to uninstall the program and remove the entire old folder. Not removing the folder yielded the same result as far as activating. After removing the old folder I reinstalled the program and I was back in buiesness.
Thanks for the help
-Del -
Cool!
svcd2dvd on windows 7
By pete11111 in forum SVCD2DVD & VOB2MPGReplies: 12Last Post: 9th Feb 2010, 21:54 -
Windows 7 Ultimate - Can't load assets in SVCD2DVD
By ttyner in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 13th Jan 2010, 10:54 -
Reinstalled Premiere pro 2, but NO TEMPLATE installed
By yunakokimama in forum Newbie / General discussionsReplies: 0Last Post: 7th Apr 2008, 12:20 -
reinstalled windows and now I can't play any video files.
By drazius in forum Newbie / General discussionsReplies: 6Last Post: 25th Jan 2008, 13:45 -
SVCD2DVD won't launch after latest Windows Update of MS .net framework
By starkraving in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Jul 2007, 03:42
