Hiya guys.
i recieved an illegal ac3 format with my dvd authoring programme.
so i ran the ac3 audio through ac3 fix, and the fixed audio now does author perfectly fine, but during playback it gives me sync issues.
i checked the runtime of the fixed audio, and i found that there is a whole second shaved of it.
so how can i fix this problem, i have ran ac3fix once before and it gave me no such problems,
thanks in advance
regards,
Mubs
Tru using DelayCut on that file. You should be able to replace the bad spot in the AC3 with silence
http://jsoto.posunplugged.com/tools/delaycut_1212_exe.zip -
but why should i need to 'replace' anything.
the fixed audio file is not long enough to start with, so whatevr i replace the fixed audio will still be the same legnth will it not? -
Not necessarily. If the fixer app cuts out a glitch that's more than a 1/30 of a second, your AC3 file is going to get smaller. Better to fix the errors, then replace with silence so the length stays exactly the same. -
so how do i 'fix' these errors?Originally Posted by Soopafresh
Fixing sound sync issues in a mkv file
By Psykro in forum EditingReplies: 12Last Post: 20th Dec 2014, 11:31 -
Fixing / Determining Audio Sync Issues With Only Some DVDs
By TheNut in forum DVD RippingReplies: 5Last Post: 12th Dec 2009, 17:47 -
Fixing Out of Sync Issues with Mp4 files?
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 13:01 -
Fixing audio sync issues when using GOTSent to convert MKV to MP4
By darrklight1138 in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2009, 06:56 -
Fixing sync problem on rmvb
By gameroftheuk in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2008, 21:16
