  1. Good Afternoon,
    I want to use MGI Video Wave to produce an uncompressed AVI file to feed into TMPGEnc (VCD or SVCD). I select uncompressed AVI, but I a confused over what is the best resolution to use. Should I pick the highest (740x576) ?
    Thanks,
    Bob
  2. Open tmpgenc and load a test .avi then load one of the templates. Click the settings and take a look at what the settings are. This will give you a clue as to how to set up your .avi.
