Hi, im new here
I just founed the forum through google.com and i hope you can help me
I have just spend 1-2 hours trying to follow the guide and i cant get it to work >< can some one help me, i got a video clip one of my fellow employeis need as fast as possible and i cannot remove the water mark >< can some one do it for me? maby its me that cannot understand who the hell vdub worksbut just desperet need the watermark on the clip removed
The clip is atm in a MPEG format if that makes any trouble? the avi version is on 1,7GB witch is a lot to host
Hope there is a freindly soul who can help meand in advance thanks for the help :]
Link to my clip : http://rapidshare.com/files/76474856/1377_a4805c735539a688ad26df2a065857ea_1_.wmv.html << its 50MB.
It would be nice if you culd upload it here or e-mail me it on CAD@Sparinvest.dk
Its only because it needs to be solved as fast as possible else i would take the time to try again and again but am under a bit of pressur so hope you can help me out this once.
IMO that watermark is going to be extremely difficult to remove without leaving an equally annoying blob. The method described in this guide can not be applied because the logo never appears before a black background. This means using the old method of sampling many frames and will probably require multiple passes to filter the variations in the color depth. Is it really that important to have the watermark removed? Can't your fellow employee learn what this video is teaching with the watermark in place? (I have no idea what's it's talking about, since I don't know the language.)
Buy My Books
How to remove huge but transparent watermark?
By Athari in forum EditingReplies: 76Last Post: 20th Aug 2011, 08:40 -
Adding watermark to video
By Shaorin in forum Newbie / General discussionsReplies: 2Last Post: 29th Nov 2010, 09:08 -
adding watermark on video
By 3390 in forum Newbie / General discussionsReplies: 5Last Post: 27th Feb 2008, 05:13 -
Add Watermark To Video?
By johngomez0468 in forum SubtitleReplies: 5Last Post: 29th Jan 2008, 16:48 -
Remove Watermark From DVD
By fatla00 in forum Authoring (DVD)Replies: 1Last Post: 16th Sep 2007, 15:00
