whenever i want to burn my project into a dvd it can never finsh...i can only burn at 2.0x or2.4x speed...how can i burn at a faster rate?
check out make skateboarding vids...youtube search kmart films
It sounds like your burner is in PIO mode. Right-click My Computer and select Manage. Click on Device Manager, then expand the branches for your IDE channels. Double-click on the primary channel and check the modes. If either are PIO mode, uninstall the channel. Check the secondary channel. Again, if either device is in PIO mode, uninstall the channel. Restart your system and it will re-install the devices. Try burning again.
If you find that neither channel is in PIO mode then you most likely have a compatibility issue with your burner and the media you are trying to use. A firmware upgrade or a change of media is called for in that case.Read my blog here.
NONE OF THAT HELPFUL INFORMATION WORKED...I DID SOME RESEARCH AND IT TURNS OUT EVEN WITH THE FIRMWARE UPDATE THE MAX. BURNING SPEED IS STILL 2.4X
IM NOT TO SURE...AT LEAST 2 TO 3 YEARS...IM USING AVI FILES FROM SONY VEGAS 6...I BOUGHT MAGIX MOVIE EDIT PRO 12 SO I COULD TRANSFER MY VIDEOS INTO DVDS
Please don't shout (typing in all capitals is considered shouting and rather rude).
Unless the media or drive is limiting you, there is no need to burn at that speed. Instead of using Magix to burn, write the results to your HDD, then use the free program Imgburn to burn to disc.
Also, Imgburn can tell you what speed your drive can burn the discs at.Read my blog here.
wow! i never knew that...my bad...ok i'll into that...THANKS!
Magix Movie Edit Pro 17 - Help
By volotre in forum EditingReplies: 1Last Post: 12th Apr 2011, 12:27 -
Magix Movie edit Pro 15 Burning problem
By wolfspirit1964 in forum Newbie / General discussionsReplies: 1Last Post: 24th Feb 2010, 03:56 -
Magix Movie Edit Pro and MP4's
By uihawks89 in forum EditingReplies: 2Last Post: 6th Jun 2008, 01:09 -
MAGIX Movie Edit Pro 12 problem
By Rein Engel in forum EditingReplies: 0Last Post: 21st Sep 2007, 14:40 -
Magix Movie Edit Pro 11 Encoder
By SCDVD in forum EditingReplies: 0Last Post: 7th Jun 2007, 18:09
