Good Afternoon,
I would like to capture uncompressed AVI from my JVC Camcorder using MGI Video Wave. The system defaults to a codec called DVSoft. Does anyone know how to change this ?
Thanks,
Bob
Select the capture icon, and click settings.
A window with the current VIDEO and AUDIO devices used are shown.
Use the arrows to the right of each to select other capture devices.
To change codecs per device select your capture device and click the
Video Template. You should see a list of types of video to use.
If you don't see the one you want you can edit the templates.
Click EDIT then NEXT. There should be a button that says VIDEO FORMAT.
Hope this helps.
Uncompressed AVI to WMV @ 30fps cannot seem to get smooth video...
By neilcooper33 in forum Video ConversionReplies: 23Last Post: 21st Sep 2010, 16:25 -
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
Is there an s-video input cable available for the JVC DVL915U camcorder?
By janbbeck in forum Capturing and VCRReplies: 4Last Post: 20th May 2010, 22:23 -
Trouble capturing video from my JVC GR-DA30 camcorder.
By Baby Mike in forum Capturing and VCRReplies: 1Last Post: 27th Dec 2007, 18:33 -
Burn'n DVD video JVC GR-D72 camcorder (((HELP)))
By sm head in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2007, 18:55
