I have an AVI file that has the wrong key-frame flag. Every frame is marked KF.
I use VirtualDub to open it with re-keying option. When I try to save the AVI, it will crash. Tried several times, same problems.
DivFix++ can't fix the file either.
Any other tool?
Thanks!
Have you read this?: https://forum.videohelp.com/topic153907.html
Google is your Friend
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Video Tutorial: Chroma Keying in FCP
By IceflowStudios in forum User guidesReplies: 0Last Post: 14th Dec 2007, 16:42 -
Need help chroma keying with Fusion (and other software) for Flash video.
By OM2 in forum Newbie / General discussionsReplies: 3Last Post: 28th Jul 2007, 20:07 -
Is There a Easy way to do Chroma Keying with Video?
By Datahead in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 20:13
