I use ConvertXtoDVD to make my AVis to DVDs, and i burn the video files with Nero. Everything finishes successfully. When i go to play the movie, it looks all pixeled. Hopefully you guys will know what i mean. Is there any settings i can tweak, or maybe use a different program that will do better quality? Any help would be greatly appreciated! Thank you!
	1. Test the conversion by playing back the files from your HDD. If they are clean, move on to step two
 2. Buy decent media. Most playback issues after burning come from using the cheapest crap you can find in the local bargain bin. Sometimes, however, even the good stuff may not be as compatible with your burner or player as you might like. Changing media to another quality brnad may fix the issue.
 3. Burn with a decent burning application. Personally, I believe Nero ran it's race back at version 5.5, and everything since then has been more and more bloated, and done less and less well. Try Imgburn for DVD video. It is the dogs bollocks when it comes to burning DVD video.
 If you have problems with the output of ConvertXtoDVD, try DVD Flick or FAVC.
 Also remember the golden rule of video - Garbage In = Garbage Out.Read my blog here.
	I vote for the golden rule. You can't take a crappy looking 700MB avi file, convert it to mpeg2, and expect to get a DVD quality image equivalent to an original DVD.
 You can also save all the conversion hassle and just get a Divx certified DVD player. Then you just burn your avi files to CD/DVD as data and play them back on your TV. They will likely still look crappy, but it will save you all the time and hassle of conversion, plus the addition quality loss from converting the files to mpeg2.Google is your Friend
	Recent editions of ConvertxtoDVD will burn the output without having to use Nero.
 You wouldn't happen to be using the old DVIXto DVD (free version) would you? It does not do as good a job of converting as the later versions.
	Use AVISynth to frameserve with Convolution3D like this example:
 AVISource("D:\Montage\Movie_1.avi")
 ConvertToYUY2() # necessary for convolution
 Convolution3D (0, 32, 128, 16, 64, 10, 0)
 Spline36Resize(640,432,0,1,352,238) # better than lanczoz or lanczoz4
 AddBorders(40,24,40,24)
 Make a good result for meShine as you should !
  Advice on DVIX/Avi dvd playersBy aelfheah in forum DVD & Blu-ray PlayersReplies: 15Last Post: 27th Jan 2011, 17:48
  Convert AVI to DVD best method advice required pleaseBy vwgolfman in forum Video ConversionReplies: 7Last Post: 1st Apr 2008, 11:01
  Pixeled image on my DVD PlayerBy mingul in forum Newbie / General discussionsReplies: 1Last Post: 3rd Mar 2008, 14:02
  Looking For Advice. I'm hoping to get some advice about a DVD burnerBy wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39
  Ok Guys, I need some advice on AVI?By Soccerman77 in forum Video ConversionReplies: 5Last Post: 26th Nov 2007, 00:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
