When I take an avi video on my digital camera’s SD card, and then put that SD card in my digital frame (5.6 Tru Photo Pan Digital) it works fine.
The problem is, I want to edit my video first and get all the garbage out.
So, I edit my video in Windows Movie Maker and save it as a DV-AVI file and save it to my SD card. So the file name becomes movie.avi.
This time when I put the SD card in the digital frame, it says file type not supported.
Can you please tell me what I’m doing wrong? The frame says it supports Motion Jpeg (AVI) files. Is the AVI I created somehow different than the Motion JPEG?
Please Help!
Er, yes - it is a DV avi. AVI is just a container. The actual content is determined by the codec you use. In your case, you need a motion jpeg (mjpeg) codec to compress the edited video.
I don't know of any free mjpeg codecs that can encode, but then I don't do a lot with mjpeg.Read my blog here.
mjpeg is not the same as DV-avi. avi come in many flavors as it is a generic term for a video+audio file. search for a program that edits and will save back to motion jpeg. i can't help you there, i don't use that format at all.
Our first editing and camera work, failure or success?
By Viacon in forum Newbie / General discussionsReplies: 48Last Post: 11th Jun 2011, 00:48 -
Please can someone help with frame-by-frame video editing?
By likasombodee in forum EditingReplies: 2Last Post: 6th Mar 2011, 20:06 -
frame server doesn't work in Premiere CS4?
By ivanadit in forum EditingReplies: 0Last Post: 6th Jan 2009, 14:46 -
Consumer video camera's that do 1 frame recording
By Jabroni4872 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 18th Aug 2008, 02:14 -
Suggest a video editor for frame-by-frame editing
By ontherocks in forum Newbie / General discussionsReplies: 14Last Post: 24th Apr 2008, 10:36
