I was told you can either hook up your XBOX 360 controller to the computer or buy a new one. Can someone either tell me how to do this or link me to the correct type of controller?
Yep I have used and will use my wireless 360 controller. though you need the wireless usb receiver from microsoft to make it work. I guess the corded usb ones can work right away with drivers.
The wireless receivers has a vista update if you are running vista like I am. Don't know about the corded drivers but I assume the same thing.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
It would be far cheaper to buy the rechargable battery pack and cable than the wireless unit,I charge mine on my laptop cos its closer than the xbox and when plugged into the usb port the pc recognises it and asks to download the software.
You might find this useful too
http://www.pinnaclegameprofiler.com/
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 03:05 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Xbox 360 streaming -- audio of out sync (fine on computer)
By ycrazyy in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2010, 10:42 -
Can I use my XBOX-Windows controller in MCE?
By dm_0001 in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Jan 2008, 18:25 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 10:06
