I have a set of video clips I'd like to encode into the appropriate size for my LCD TV, using SUPER Encoder. This will be an NTSC-format disc, therefore, I'm assuming the screen resolution should be 720x480.
I've tried encoding to several formats - including AVI, VOB and MPG, and I got the same result. (Except I don't get any volume in which the audio codec is AAC.)
Now, here's the problem I'm experiencing:
1) An image (such as the Chapter menu) of 720x480 fills the screen vertically as it should.
2) A video clip of 720x480 don't fill the vertical space...it leaves about a 3/4" space on top and bottom.
3) A video clip with a height of 576 fills the vertical space and doesn't go over.
Are there any other factors during the encoding process which could prevent the 720x480 output from filling properly? Isn't 720x480, by default, supposed to fill the vertical space?
Any help is appreciated. Thanks!![]()
AnonymousGuest
AnonymousGuest
No - it encodes in 4:3 or 3:2 - which both appear to be the same. My TV is 16:9, roughly, and it gets the horizontal correct, but not the vertical.
AnonymousGuest
Whoa. I just downloaded this utility, and I'm overwhelmed. What am I looking at?????
Screen doesn't expand to the max of the HDTV width and height.
By wishstar99 in forum ComputerReplies: 11Last Post: 30th Aug 2010, 12:08 -
1280x1024 Resolution doesn't fill screen?
By mccoady in forum ComputerReplies: 20Last Post: 17th Oct 2008, 19:56 -
Should 16:9 video fill the entire screen on a new HD Plasma TV?
By Rkevin in forum Newbie / General discussionsReplies: 3Last Post: 1st Jan 2008, 18:17 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 04:37 -
picture doesn't fill TV screen - let me back up and start over.
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 15th Aug 2007, 22:48
