OK I did succesfully download the PAL miniDV using NTSC SONY camera.The video seems to be playing well on the computer.An hour file is 12.5 GB because I used the highest quality WMM setting.Yesterday I used DVDFlick to compress this large file and as well burned it to a DVD with the help of this software.The result isn't good.The video flow is very uneven.When the camera films stationary objects that all is fine but as soon as the video is capturing moving scenes than the picture starts to jerk.I'm not sure how to proceed now.Shrink and Nero won't burn the this PAL file,maybe beacuse it's processed with NTSC camera,I don't know..Maybe there is some other free program on the net which I can use instead of DVDFlick.Hopefuly there in the cyber cosmos is some experienced Cpt.Jean Luc Picard who will be able to find a solution to my problem.Please note,I'm a broke student [macaroni and cheese is my staple food these days]and can't afford any of those $$$$ sofisticated softwares.Thank you.
If you produces a WMV file then you should really start again and output as DV-AVI from WMM.
The problem sounds like a poor quality format conversion. Because of the process you are using this could have happened anywhere from the camera, through WMM to DVD Flick.
To get the best solution you need to get a PAL DV AVI file from the camera, and process this. I don't know what process DVD Flick uses for converting PAL to NTSC. I do know that FAVC uses the pulldown method, which will give you the best results, however you must have a clean PAL source video for it to work.Read my blog here.
Anyway to save flow player video's?
By scustalow in forum Video Streaming DownloadingReplies: 10Last Post: 4th Mar 2017, 18:33 -
Stuttering video when converting with dvd flick
By Ze Tomes in forum Video ConversionReplies: 13Last Post: 15th Dec 2011, 12:15 -
Merge video files in DVD Flick?
By morgle in forum EditingReplies: 6Last Post: 13th Aug 2010, 10:28 -
Jumpy Video with DVD Flick
By matthewjohn23 in forum Newbie / General discussionsReplies: 2Last Post: 16th Jul 2008, 21:24 -
Cam Video Tool 4 DVD Flick
By AleksandrIgnatov in forum Video ConversionReplies: 0Last Post: 2nd Jun 2007, 22:55
