Hi, i have two .AVI files and useing TMPGEnc i have converted these files to .MPG files. Now i want to merge these two files into One so i can burn useing Nero, i know i can burn the two files on seperate disks, and have two halfs of this movie, but i dont want to do that. i think i can use TMPGEnc or some other soft ware to merge these two together. i just fogot how to do this , need help please.
Morefeus
bruce1
Personally, I would burn with Imgburn, but that is just me.
If you just want a large mpg file then you can use mpg tools in tmpgenc to append them.
If you want a DVD, use DVD Flick, add them both to the one title, and it will create a DVD structure for you. By default DVD Flick does not re-encode compliant mpg source files.Read my blog here.
If you mean mpg file 1 + mpg file 2 = one new mpg (or vob) file, you can use this trick:
At the command prompt, enter:
copy /b file1.mpg+file2.mpg merged.mpg -
Or demux into one large Video.m2v and Audio.ac3 (or MP2 or WAV). DGIndex can be used for this. Open both MPGs at the same time, which effectively joins them. Then File->Save Project File and Demux Video. Take the resulting joined M2V and AC3 files and use in an authoring app. Muxman is perhaps the easiest. This assumes they're already DVD compliant to begin with.
Merge multiple audio tracks from different files into 1 video file - sync
By heinza in forum Newbie / General discussionsReplies: 2Last Post: 11th Jan 2012, 03:29 -
How to Convert DVD files to .mpg/.wmv/avi for editing in Win Movie Maker
By Injasuti in forum Newbie / General discussionsReplies: 4Last Post: 8th May 2011, 03:47 -
Very basic question...... how can I merge mpeg files and make a movie
By True Colors in forum Newbie / General discussionsReplies: 5Last Post: 30th Oct 2009, 16:45 -
How to merge subtitle file with movie when it is being burnt ?
By dilanalex in forum SubtitleReplies: 3Last Post: 7th Apr 2009, 03:15 -
DVD Lab Pro - Question about movie merge
By shashidar in forum Authoring (DVD)Replies: 4Last Post: 17th Jan 2008, 15:41
