why do mpegs play with green flashing lines obscuing the picture?? I am using windows media to play them. Am i missing a codec??? Help please!!!!!
Try playing one with VLC Media Player. If it works properly, then you may have a corrupt codec. You could also check one with Gspot 2.70 and it will tell you if you have a missing codec. But if it plays at all, the codec is probably there.
If you just need a MPEG-2 codec, try Stinkys MPEG2 Codec. If you have installed any codec packs, that may also be a problem.
If it's not a codec, it could be a problem with your video settings, but that would usually be the same for all codecs and players.
Cyberhome CH-DVD 400 green light flashing
By Kalash109 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 31st Jan 2010, 03:59 -
What are these green lines across the frame?
By tsu3000 in forum RestorationReplies: 2Last Post: 26th Nov 2008, 17:41 -
VirtualDub - Flashing lines on playback
By terrypin in forum Newbie / General discussionsReplies: 9Last Post: 28th Aug 2007, 05:27 -
VLC green lines?
By jwfc in forum Newbie / General discussionsReplies: 0Last Post: 26th Aug 2007, 01:43 -
DivX Video with Green Lines
By sweetfreek in forum Software PlayingReplies: 5Last Post: 23rd Jun 2007, 15:05
