Hi, I have some home movies that some one has created in the following format,
there are about 6 different movies each in their own folder and each folder contains these files with exactly the same file names, I have burnt the first movie of the 6 on to DVD and it plays fine but I don't want to waste 1 dvd per movie as they are only about 500-600mb each, I'd like to put them all on 1 DVD, how can this be done?
Many Thanks for your help
Stewart
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_1.VOB
Thanks for the quick reply, I'm very thick when it comes to things like this, I am going to use TMPGEnc DVD Author is that right?
Just use DVDShrink in Re-Author mode to make a compilation...no menus
http://www.dvdshrink.info/compilation.php
If you want menus then use TDA....." Who needs Google, my wife knows everything" -
Titlewriter can add a menu to that compiliation fast -- simple but comprehensive
Very specific issues with VOB and IFO
By Eve8008 in forum SubtitleReplies: 7Last Post: 5th Aug 2010, 14:23 -
recreating vob ifo files
By krohm in forum Authoring (DVD)Replies: 25Last Post: 15th Jun 2009, 05:27 -
What should i do with vob/ifo files?
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2008, 01:26 -
Create IFO from VOB w/o IFOEDIT?
By theschles in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 18:19 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
