hi ive been trying to convert mkv to dvd so i can play it in my hd dvd. i can convert it to dvd but every software i use bring down the resolution. the mkv is 1280x720 but after encode it bring it down to 480. should i maybe convert the mkv to evo and burn that on dvd and try to play it and see if it works?? thanks
DVD is max 720x480/576. So yes you need a hd-dvd authoring/converting tool that makes evo like Ulead DVD Moviefactory. https://forum.videohelp.com/topic341999.html
Extract the video stream from the .mkv with mkvtoolnix,
then use mp4box or something to place it into an mp4 container.
(I'm assuming you have gotten an H264 video)
Open it in GSpot, or MediaInfo --- or Media Player Classic
(menu "File", item "Properties", tab "Details").
https://forum.videohelp.com/topic341999.html , probably easiest to use alltoavi and then ulead.Originally Posted by hksdrager
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Need guide for EVO -> MKV
By swiss in forum Blu-ray RippingReplies: 4Last Post: 27th Aug 2008, 16:36 -
HD DVD .EVO to .MKV (I need a real simple method)
By craig198 in forum Blu-ray RippingReplies: 0Last Post: 26th Aug 2008, 14:24 -
HD-DVD video files (eg. EVO) - any plans to support?
By broaddd in forum ffmpegX general discussionReplies: 0Last Post: 29th Feb 2008, 19:49 -
HD-DVD (.evo) or BluRay (.m2ts) --> ANY other format
By z0diac in forum DVD RippingReplies: 3Last Post: 12th Jan 2008, 06:52
