Results 1 to 12 of 12
    Jun 2007
    South Africa
    I need a Virtualdub that can fully handle,edit,encode wmv and wma files,is there someone that is up for the challenge?
  2. Not without being sued by Microsoft.
    Jun 2007
    South Africa
    yip but it wont be distributed its for my personal use only
  4. combine virtualdub with an avisynth script and you will be at least able to open wmv/wma files. To encode, very easy, just frameserve your virtualdub projet to Windows Media Encoder.
  5. Banned
    Jun 2007
    UNREACHABLE
    You can encode WMV3-video in an AVI container with
    VirtualDub, or use WMVMuxer if you prefer the ASF way.
    https://forum.videohelp.com/images/guides/p1755307/wmlic.png
  6. Or try VirtualDub 1.3c which was the last version withWMV support -- before Microsoft threatened Avery Lee.
  7. Member GMaq's Avatar
    Mar 2004
    Canada
    ha ha, That's a good one!
    The latest virtualdub 1.7.7 has ability to handle .wmv with plug-ins by fcchandler the developer of VirtualDub MPEG-2, You can now just add his plugins to Vdub 1.7.7 and open .wmv and MPEG-2, without having to run a separate VirtualDub for each task.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Virtualdubmpeg2 has also some wmv support.
  9. Banned
    Jun 2007
    UNREACHABLE
    http://thefreecountry.com/
  10. Member GMaq's Avatar
    Mar 2004
    Canada
    DarrellS,
    Great Links! Thanks!
    Nov 2002
    You're welcome.
    There is also an ac3 input plugin but it only works in the experimental releases which have Audio From Other File instead of WAV Audio. You can input 5.1 mp3 and 5.1 ac3 audio and direct stream copy to get 5.1 surround in your AVI with the experimental releases.
    http://fcchandler.home.comcast.net/Plugins/AC3/AC3.zip
    http://www.virtualdub.org/beta/VirtualDub-1.7.X-test6.zip
    VirtualDub-1.7.X-test6 is the version that I use.
