Hi
All I want to know is:- my current firmware 1.0 .What I want to know is do I have to put version 1.1 then 1.2 and finally the latest which is 1.3 or can I just put 1.3 over top of 1.0? The only reason im asking because back in early days of dvd burners some needed the earlier versions to make the newer versions work ?
THANKS
Just install the latest version. You can also update the unit over your LAN if you can connect it.
Google is your Friend -
Thanks for the advice.Tryed to update using the lan connection.But there are to many updates (39) so it never gets to the end of the list. Usally stops about update 6 saying cannot find server.Then when I press ok it drops all the updates that ive already downloaded.(got f**ked off after the 20th time).Finally found this website
http://tesc.toshiba.co.uk/Web/ModelLis.nsf/DynamicStatic/HD%20DVD%20Firmware?OpenDocument
with the latest firmware.
By the way how do you know its alright to do this operation ?
THANKS -
Just found the answer .
http://www.toshibahddvd.co.uk/media/File/FW1_1.pdf
Thanks anyway
Toshiba firmware
By betocchi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 23rd Nov 2009, 04:30 -
HDDVD to Blu-ray playable on standalone BR player
By miko611 in forum Blu-ray RippingReplies: 1Last Post: 30th Apr 2008, 08:26 -
Looking for a Good Backup HDDVD Player??
By ofield1 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 17th Mar 2008, 14:01 -
Have lower hddvd and bluray player prices tempted you?
By yoda313 in forum PollsReplies: 90Last Post: 4th Nov 2007, 23:44 -
Firmware for Toshiba HD DVD player
By tmelo38 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 1st Nov 2007, 20:02
