VGA does support 720p+ right?
A user named 007Craft posted this 4 months ago, and wanted to build on it for use of ALSO a Playstation 3. My xbox 360 is lucky enough to have a VGA, but my PS3 does not have a VGA output cable so I need to use a workaround.
Here is the original post:
Now... After knowing all that I tried to think of a variation of this process as follows:Originally Posted by 007Craft
Here's a link to the Neoya ( http://www.x2vga.com/ ). This will work great because I can plug in both my consoles into this little device via component which will convert the connections into a VGA usable (This will be great so I don't gotta keep unplugging the consoles and can switch them on the fly). The VGA will then plug into the VGA Amplifier and everything will go on like in the original diagram.
Would this small modification still work? And would it still allow me to play in 720-1080p, but record at the lower quality of 480i?
Also, since his TV Convertor doesn't exist (Tigerdirect doesn't stock it anymore) I'd probably switch it with something like this [ http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=422949&CatId=1430 ]
First let me say that if your going to be playing through component cables, you might want to consider something like this http://www.myhava.com/product_hava_wireless_hd.html. It will allow you to do everything in the diagram, except much easier, and roughly the same price. The down side to this device of course is your limited to component playback, where my method was designed for higher quality playback (notably 1080p which requires VGA). If you dont care about 1080p, then you might want to use the Hava @ $170 (or less? check ebay).
Now ignoring whats posted above, technically your diagram should work. You might experience another slight bit of quality loss due to the added conversion done by the X2VGA. It should not be too noticable however. That grandtec product you linked too seems to be better then mine. Dedicated positioning switches and a remote. Thats one of the worst parts about mine, resetting the positioning each time but it looks alot easier now with a remote and dedicated switches. Also the price is like $30 less then what I paid. good to see technology always getting cheaper and better
Heres a link to a Gears Of War montage I made without the youtube slaughter.
http://www.megaupload.com/?d=NS4UAHM7
Im buying a new quad core rig in a couple weeks and am getting rid of my pvr-150. I want to buy a pinnacle pctv hd card (which will work with pinnacles easy record software which does not support hauppage cards as well as work with adobe premier).
I have also since switched to an xbox 360 elite so im on hdmi now and need a new way to record but am stuck because of the HDCP presented in hdmi/dvi. I wish we could just record in hd but that lame HDCP is stopping us. The only affordable hd capture card on the market is the black magic intensity but without hdcp support, its only good for recording stuff off an hdmi output video camera. Right now I have to switch to vga if I want to record and I dont like that
My TV is the only TV that can support resolutions higher than 480p. The thing is, it being only a 40 inch... The difference between watching/playing in 1080p and 720p on such a smaller TV is actually very minimal. A 1080p option is quite more expensive which is in the end... why I only need 720p.
I just don't get what the heck that thing does... What would the HAVA do in this situation? How would I connect it to a capture card (I assume I'd still need one)? (I assume somehow wirelessly or something).
cleaning video, does this make any sense?
By deadrats in forum Video ConversionReplies: 44Last Post: 9th Dec 2009, 22:03 -
Does this convert formular make sense?
By helenw in forum Video ConversionReplies: 0Last Post: 26th Oct 2009, 18:04 -
From Letterbox to Anamorphic. Does it make any sense?
By Instant Martian in forum DVD RippingReplies: 4Last Post: 9th Aug 2009, 13:40 -
aspect ratio question/does this make sense?
By deadrats in forum Video ConversionReplies: 5Last Post: 24th Dec 2008, 18:22 -
Does it make sense to use Iphone without AT&T service ?
By SingSing in forum Newbie / General discussionsReplies: 10Last Post: 21st Sep 2007, 03:32
