Will I see any difference in quality? Does anyone have better "perks" over the other? What justifies the ATI being $40 more expensive over the hauppauge?
I hear that the hauppauge is worse if your using it to not only be a PVR, but capture video game console footage too because it's got a 1-2 second buffering delay.
Both of these cards have a delay in displaying a incoming video signal. Should be no problem recording game playing if your console has dual outputs, or if you split the output between Tuner Card and TV using a VCR.
Check the features and specs on both cards and you will see the 650 also handles certain digital inputs.
The 650 card has hardware DRM, so I wouldn't touch it with a ten foot pole. -
The 650 is also an ATSC tuner for over the air DTV reception. The PVR-150 has an analog NTSC tuner.
I haven't used the 650 but the 550 can capture S-Video uncompressed or it can encode to MPeg2 in hardware. The PVR-150 always encodes to MPeg2. As for stability and general application support, the PVR-150 wins there.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
ATI TV Wonder 650 USB Dual TV Tuner
By s3r19lk1ll3r in forum Capturing and VCRReplies: 9Last Post: 4th Dec 2010, 23:52 -
capture VHS with Hauppauge PVR 150?
By shun in forum Capturing and VCRReplies: 13Last Post: 24th Jul 2010, 19:11 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppauge PVR 150 compatibility with my OS
By GangstaRap in forum Capturing and VCRReplies: 11Last Post: 14th Mar 2008, 11:03
