Hello,
I am very new to video restoration and would liekt o be pointed in the right direction. I have several VHS tapes that I guess were recorded with a bad camera. They have a thick line in the middle of the video, and the video quality itself is not the greatest. It almost looks like the tracking is way bad, but I tried them on multiple VCRS with no luck. I just now ripped the VHS tapes to VCD MPEG format on my computer.
The question I have is.. Is there any easy to use software that can automatically fix these? Price is not an issue. Can someone point me in the right direction?
Thanks!!
Sounds like tracking problem. Try a stabilizer. If that doesn't work you need a Jvc svhs with filters 76xx-99xx. Theres no software to fix tracking problems but the Jvc can stabilize a better signal.
Hello,
Since I am so new, these buzzwords are all foreign to me
What is a stabilizer? Can you be more specific? Where can I get one and how much does it cost? ARe there places that offer these services for money so I wouldn't have to do it myself?
Thanks! -
Stabilizer generally stabilize the picture, there are many like Sima. You can find a lot of different brands on Ebay or Nextag. Myself and many others on this site do restoration services. Check around and get the best price and see what fits your agenda. Hope that helps...
If the tape itself has a crease down the middle, this will cause a line on the screen. TBCs, stabilizers, different VCRs etc aren't going to help with that!
Cheers,
David. -
A stabilizer won't help here, no.
(That said, I've got extra stabilizers that I want to part with cheaply.)Want my help? Ask here! (not via PM!)
Its not from the tape, because all my tapes are like this. It was likely the camera's fault
Thanks!
Best UK PAL VHS / D-VHS machines for digitising old VHS tapes
By pauldsc in forum RestorationReplies: 8Last Post: 6th Jan 2012, 09:21 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 20:36 -
Newbie converting old VHS tapes to digital - but get wavy/scrambled lines
By roguewarrior in forum Capturing and VCRReplies: 7Last Post: 25th May 2010, 21:16 -
Lines in middle of video when panning or zooming in/out
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 11th Jun 2008, 17:31 -
Wavy lines on tv reception (tapes too!)
By JudgeGarth in forum DVB / IPTVReplies: 4Last Post: 27th Feb 2008, 10:56
