Is there a way to add sub titles by using svcd2dvd alone or do I need another program? any advice would be appreciated.
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
What the heck is that screenshot? Is that part of svcd2dvd? I expected more help from the forum. I did a search on this forum and this seems to be the common answer - show this same screenshot with no other info. Anyone else have any answers that can actually help a beginner?
Not sure what your issue is Dick...
You need to turn your text based subtitles to the binary .sup format.
So start SubtitleCreater, load up your text formatted subtitle file (e.g .srt file) and save it as a .sup file (as per the screenshot).
Then rename the .sup file so you have something like:
nameofmymovie.avi <---- your asset
nameofmymovie.sup
in the same folder.
Load you asset as normal and SVCD2DVD will added the subtitles automatically.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thanks for the explanation. I have been using svcd2dvd for quite some time and had never had the need to add subtitles. I kept clicking every menu button trying to find the submenu called subtitle creator. Dumb me, I searched videohelp and found that is was a stand alone program. I just downloaded it and am going to try it tonite.
Adding controls to a swf (then adding to website)
By AshleyQuick in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2011, 03:02 -
Titles Intros.
By ozab in forum EditingReplies: 3Last Post: 17th Feb 2009, 19:00 -
Need help with adding titles, credits and music to an avi
By dpoon in forum Newbie / General discussionsReplies: 1Last Post: 4th Feb 2008, 14:06 -
No Titles
By jinboleone in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2007, 18:55 -
Adding animated titles
By SearchQuality in forum EditingReplies: 8Last Post: 30th Nov 2007, 18:27
