Every single time I convert flv to avi the avi will have little squares or boxes in it. Is it normal when you convert flv to avi for them boxes to always be there and if so how can I remove them. When converting flv to avi I have noticed that the avi files can be quite large at times, is flv compression that much better than divx compression? The only way I have seen to stop the big size is using vdubmod and FLVExtract. To bad there isnt a program or script that will perform all the steps so all you have to do is pic the flv file and let it do the rest lol.
Vdownloader
The squares are called macroblocks, and are usually caused by low bitrate of the original flv file. -
You could try the deblocker filter from MSU: http://www.compression.ru/video/deblocking/smartdeblocking_en.html
FLV is meant to the the end product, so converting it to another format will always give some quality loss.
I tried that wasnt happy with it. Reckon I am screwed. I wouldnt be converting the flv files at all if there was a way to make then seekable.
Tools needed to understand source file:Originally Posted by dread
GSpot
https://www.videohelp.com/tools?toolsearch=gspot&Submit=Search ... rfeatures=
MediaInfo
https://www.videohelp.com/tools/MediaInfo
Conversion software:
ALLtoAVI
https://www.videohelp.com/tools?toolsearch=alltoavi&Submit=Sea ... rfeatures=
You will need to play with the VIDEO BITRATE or QUANTIZER in ALLtoAVI to get the quality you want. This is where GSpot and MediaInfo come into play as you compare the source file specs against the destination .AVI file.
Last but not least you might need:
AVI ReComp
https://www.videohelp.com/tools/AVI_ReComp
The program allows you to recompress your AVI files. Uses only XviD codec to recompression process. AVI ReComp can be very useful for users who want to clear their AVIs out of GMC or Qpel functions to prepare the clips for standalone DVD players.
Best quality flv to avi conversion
By Johnbil in forum Video ConversionReplies: 4Last Post: 22nd Mar 2012, 19:05 -
Help : FLV to AVI Slow Conversion
By d3ck in forum Video ConversionReplies: 9Last Post: 22nd Jun 2011, 04:55 -
Having trouble with a conversion (mp4 / avi / mov / flv)
By loxley in forum Video ConversionReplies: 4Last Post: 23rd Feb 2009, 11:17 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
Strange colour on AVI to FLV conversion
By Ian J Richards in forum ffmpegX general discussionReplies: 2Last Post: 6th Nov 2007, 11:05
