OK Guys, I've been using filmguard and a kodak film cleaning solution for years. Now I've found out that they are being discontinued. Do any body knows a cheap alternative that will be just as good on cleaning film. Thanks!!
You could look up the Material Safety Data Sheet (MSDS) for the Kodak cleaner and mix it yourself.
I actually look at the MDS sheet the stuff they used seems to alcohol mix with some oil. But that seems risky...
http://www.film-center.com/clean.html
If you use alcohol make sure it is isopropyl,do not use rubbing or denatured alcohol because it has acetone which will desolve your film.
8/16mm film to video question
By spiritgumm in forum Video ConversionReplies: 10Last Post: 27th May 2011, 17:16 -
remastering FILM 16mm/35mm
By iigood in forum Video ConversionReplies: 8Last Post: 4th May 2010, 00:18 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
How to make a DVD from 16mm film
By old-school in forum Newbie / General discussionsReplies: 4Last Post: 5th Dec 2007, 21:12 -
Top quality professional transfer of 8mm and Super 8mm film
By cosmichippo in forum Video ConversionReplies: 75Last Post: 25th Jul 2007, 22:28
