  1. I am making a dvd with many menus and options. I want to be able to press a number button, 1-9, on my remote to choose the buttons on the menus. How do you set that up? Some of my menus have 8 buttons and its a pain to keep pressing the arrow buttons. Also, when playing the dvd on my tv, the color change when a certain button is highlighted, is only a few shades differant from the ones that are not highlighted. This makes it difficult to tell wich menu button you are currently on. Is there a way to change the color of the highlighted buttons?
  2. Banned
    Jun 2007
    UNREACHABLE
    AFAIK, whenever you assign a link/connection to a button on a menu,
    the corresponding remote button number is assigned to it as well.
    Therefore either your standalone is having a problem, or DVD-lab
    is not compiling your projects correctly.
    http://www.mediachance.com/dvdlab/Help/
  3. Banned
    Jun 2004
    ®Inside My Avatar™© U.S.
    And you can also change the color of the Selected links and the Activated colors from the menu to the right under MAP when working in any menu.
  4. Thanks a lot guys. I will give it a try tonight. Much appreciated.
