I've managed to get video from VHS -> DVD Recordable -> Computer. Now I 've managed to edt the video, which runs and plays fine. Now I need to turn it into a codec which is runable on any windows PC (xp or later), which has no internet connection. IE I need to put it into a codec that windows natively supports. I can't seem to find a list of codecs that windows comes with (only that it supports avi, mpeg, etc).
Does anyboduy know of a codec or list of codecs I could use? And the best way to change from the current codec to the natively supported one?
If your wondering why, the video contains footage my boss want to use in a power point presentation which he shows all over the world. He wants the presentation on a memory stick but doesnt want the people running the presentation to have to start installing codecs. I can't guarentie the conference computer will be hooked to tthe internet for media player to automatically download the codec im using.
I've currently managed to get the video from VRO into both avi and Mpeg fromats using Avidemux
You could also include a player on the flash drive, most aren't very big.
Google is your Friend -
You can get Mplayer and VLC media player in a compact format for flash drives here, along with other useful compact programs: http://portableapps.com/apps
Yet another option would be MakeInstantPlayer (freeware) to make a self-running video file. I tried it out a few months ago and it worked fine. Uses Mplayer code so should work with most any video format.
http://mulder.dummwiedeutsch.de/home/?page=projects#instplay
Review:
http://www.softpedia.com/reviews/windows/MakeInstantPlayer-Review-49499.shtml -
You can also convert the file to mpeg-1 format + mp2 for audio.
It will play on any windows version from 95 to Vista.
VFAPI Codec Problems
By [K]eep[A]way in forum Newbie / General discussionsReplies: 20Last Post: 8th Sep 2011, 06:40 -
Codec problems with mov, mp4 and wmv
By lyrd in forum LinuxReplies: 15Last Post: 29th Jul 2008, 14:30 -
Converting MOV to FLV - codec problems
By communique in forum ffmpegX general discussionReplies: 5Last Post: 13th Jun 2008, 14:58 -
Codec problems via website only ?
By yukon33 in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 14:19 -
Codec problems after installing k-lite
By woolf-gang in forum Software PlayingReplies: 9Last Post: 28th Sep 2007, 08:56
