Results 1 to 9 of 9
    Mar 2006
    Couple of issues:
    1) This morning I am trying to make a DVD from a couple of video files and it is taking FOREVER to crunch them - 2 x 800mb each and after an hour its done 3% of the first one - the FPS says "1". Starts out at 26fps then falls through the floor after 10 seconds.
    Not the usual performance at all - in fact I did another just before this one and it took the usual 45 mins or so just the same as all the others I have done.
    Was using an earlier version of 2.5 (under XP) but have just downloaded the latest 2.5 (reg version) - no difference!
    BTW the files play just fine on the PC, my Buffalo Link Theater and also in SVCD2DVD itself, so its not a broken file...
    Any ideas guys?
    2) Sound! I think it started with 2.5... I make DVD's of stuff for my friend who's DVD player doesn't downmix properly and doesn't have a 5.1 setup. Now, the software used to give me dvd's which worked well, but now... dunno what has changed!
    I currently sort of resolve the issue with the convert to mp3 and uncheck the "leave AC3 alone" box but its still not as good as the program used to be.
  2. Member guidorobben's Avatar
    Feb 2004
    Netherlands
    Could you post your log?
    Mar 2006
    If you could tell me how... sure!
    Mar 2006
    Aha! Did a search on here and found where the log files hang out - have only ever posted up the crash/debug stuff on here before, but this isn't a crash
    Anyway, here you go, only the filenames have been changed to protect the innocent
    ************************ SYSTEM INFORMATION ************************
    ***************************** SVCD2DVD *****************************
    Title: 2.5
    Version: 2.5.3600.0
    Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
    Executable size: 2.57 MB
    Executable size in bytes: 2703443
    Executable CreationTime: 09/12/2007 17:41:26
    Executable LastWriteTime: 12/12/2007 09:51:47
    Executable LastAccessTime: 12/12/2007 09:52:04
    ************************* Operating System *************************
    Operating System: Microsoft Windows XP Professional
    Service Pack: Service Pack 2
    Version : 5.1.2600
    Windows Directory : C:\WINDOWS
    OSLanguage: 1033
    CodeSet: 1252
    CountryCode: 44
    Local: 0809
    Total Physical Memory: 1.99 GB
    Free Physical Memory: 1.35 GB
    Total Virtual Memory: 1.99 GB
    Free Virtual Memory: 1.95 GB
    ***************************** Computer *****************************
    Computer Manufacturer Name: NVIDIA
    Computer Model: AWRDACPI
    System Type: X86-based PC
    Computer Name: NAPALM
    DomainRole: x2c3419cdc9b8e007
    Number Of Processors: 2
    User Name: NAPALM\user
    ***************************** Processor ****************************
    Manufacturer: AuthenticAMD
    Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
    Description: x86 Family 15 Model 43 Stepping 1
    CPU Speed: 2.412GHz
    CPU FSB: 200MHz
    L2 Cache Size: 20.5 KB
    CPU Speed: 2.412GHz
    CPU FSB: 200MHz
    10:07:02: Logical CPUs: 2
    ***************************** Time Zone ****************************
    Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
    ****************************** VIDEO *******************************
    Name: NVIDIA GeForce 7900 GT/GTO
    Processor: GeForce 7900 GT/GTO
    Mode: 1024 x 768 x 4294967296 colors
    Video Ram: 256 MB
    Status: OK
    ****************************** Drives *******************************
    DeviceID: C:
    FileSystem: NTFS
    FreeSpace: 41.1 GB
    DeviceID: D:
    FileSystem: FAT32
    FreeSpace: 24.7 GB
    DeviceID: E:
    FileSystem: NTFS
    FreeSpace: 49.8 GB
    DeviceID: F:
    FileSystem: NTFS
    FreeSpace: 12.6 GB
    DeviceID: G:
    FileSystem: NTFS
    FreeSpace: 12.6 GB
    ********************* END OF SYSTEM INFORMATION ********************
    ************************* ProjectMetaData **************************
    <?xml version="1.0" encoding="utf-8"?>
    <SVCD2DVD DateTime="12/12/2007 10:07:03" Filename="NONE">
    <AssetSet>
    <Asset ID="fa93d29a-b07a-42cc-a1d5-a249afb7ef55" Path="F:\tv\films\videofile" Filename="dmd-videofile-cd2.avi" />
    <Asset ID="85d49296-8176-499c-9e3d-761c1af4c8ac" Path="F:\tv\films\videofile" Filename="dmd-videofile-cd1.avi" />
    </AssetSet>
    <DVDStructure>
    <TitleSet Name="New Movie" PostCmd="" MenuButtonType="0">
    <MenuButton X1="0" Y1="0" X2="226" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">New Movie</MenuButton>
    <Title Name="dmd-videofile-cd1.avi" AssetID="85d49296-8176-499c-9e3d-761c1af4c8ac" MplexOffset="0" />
    <Title Name="dmd-videofile-cd2.avi" AssetID="fa93d29a-b07a-42cc-a1d5-a249afb7ef55" MplexOffset="0" />
    </TitleSet>
    <DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2.5\default.jpg" AudioPath="" />
    </DVDStructure>
    <Settings>
    <General InitialAssetFolder="F:\tv" InitialDVDFolder="E:\dvd" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="True" UseDVDShrink="False" />
    <Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
    <Process AudioEncoding="skip" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="False" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" OrderAudioStreams="False" ProcessIfNavPacks="False" />
    <Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
    <Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
    </Settings>
    </SVCD2DVD>
    Processing assets for DVD creation
    =================== AV Details ===================
    File Size: 696 MB
    file=F:\\tv\\films\\videofile\\dmd-videofile-cd1.avi
    FormatName=avi
    Num_Frames=95283
    DurationInSecs=3974
    Duration=01:06:14.1
    VideoCodec=mpeg4
    VideoFFSTNum=0
    Width=640
    Height=272
    Standard=NTSC (Film)
    BitRate=1469
    AudioStreamCount=1
    Audio1FFSTNum=1
    Audio1StreamID=[0x1]
    Audio1SampleRate=48000
    Audio1Codec=ac3
    Audio1BitRate=448
    Audio1Channels=6
    AVI2MPG: 4512kbs Full-D1
    10:07:03: Looking for AVI PAR...
    Pass 1/1: Processing dmd-videofile-cd1.avi
    10:07:04: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
    10:07:04: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
    10:07:04: libavutil version: 49.1.0
    10:07:04: libavcodec version: 51.27.0
    10:07:04: libavformat version: 51.12.1
    10:07:04: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
    10:07:04: Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (24000/1001)
    10:07:04: Input #0, avi, from 'F:\tv\films\videofile\dmd-videofile-cd1.avi':
    10:07:04: Duration: 01:06:14.1, start: 0.000000, bitrate: 1469 kb/s
    10:07:04: Stream #0.0: Video: mpeg4, yuv420p, 640x272, 23.98 fps(r)
    10:07:04: Stream #0.1: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
    10:07:04: Output #0, dvd, to 'F:\tv\films\videofile\dmd-videofile-cd1_S2D.mpg':
    10:07:04: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 4512 kb/s, 23.98 fps(c)
    10:07:04: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
    10:07:04: Stream mapping:
    10:07:04: Stream #0.0 -> #0.0
    10:07:04: Stream #0.1 -> #0.1
    10:07:04: Press [q] to stop encoding
    Mar 2006
    Gave it all day to crunch those files and when I came home tonight it had crashed
  6. Originally Posted by desantnik
    Is there a log?
    Dwight
    "A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
    - Herm Albright
    www.martialconcepts.com
    Mar 2006
    No, the machine had totally wiped out.
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I think the issue is downmixing from 6 to 2 channels.
    I will do some tests at this end.
    Mar 2006
    Which issue Chris?
    The slow FPS or the ongoing sound problem?
