Hi Guys, Its been awhile since i posted here (about 2-4 years actually)
and my new PC is almost done, and it will come equiped with a PCI-E Black Magic Intensity Pro HDV Tuner Card, Capable of Recording FULL 1080,
anyways, other than recording i was wondering if there is a FREE tuner Program I can Download to open a LIVE stream from the device and full screen it.
Basically, I know VLC works with my older tuner cards but not sure about this one, site says its Direct Show Compatible.
Doesnt Virtual Dub or something have a "Full screen" option
Windows 7 Ult.64,MSI K9N Plat. SLi,Athlon64X2 6000+@3.2GHz, 2GB DDR2 XMS2, eVGA GF8800 GTS SSC 640MB, Intensity Pro 10-Bit HDMI Video, Creative XFi Fata1ity Plat.
sorry, i done figured all i needed to out, and I am now capable of recording 720p and 1080i via YPrPb or HDMI.
Windows 7 Ult.64,MSI K9N Plat. SLi,Athlon64X2 6000+@3.2GHz, 2GB DDR2 XMS2, eVGA GF8800 GTS SSC 640MB, Intensity Pro 10-Bit HDMI Video, Creative XFi Fata1ity Plat. -
Are you talking about wifi streaming??? B or G wifi won't cut it for high def. Unless maybe you are on a point to point line of sight connection and can max out at 54G. You'll either need to be on a lan connection, powerline connection, or possibly wifi N to get anywhere near a fast enough hiccup free high def viewing over wireless. At least that is the case in my experiment with wifi G. I tried streaming a 720p .tp file and it wasn't a smooth experience and really suffered hesitations.
Now if you want to do sdtv over wifi then G should be more than enough. I was able to that through a second floor pc with a standard def mpeg 2 file and had no problems whatsoever. I can even fast forward through it.
But as mentioned to use it as a forced feed to the tv you'll need something a lot faster the B or G wifi. Try N or a physical connection for better reception.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Dude, READ my First Post, and Google The Hardware I Listed,Originally Posted by yoda313
I Was Asking if there were Direct Show REcording Programs that have a Full screen capability with no time delay.
I FIgured it all out on my Own, My Xbox360 and HD DVR are Hooked to a 5 Port HD Switch, and the YPrPb Cables frmo the Switch goto the ANalog Inputs on my Black Magic which is a Hardware High Def Recording PCI-e Card,
No where did I say WiFi.Windows 7 Ult.64,MSI K9N Plat. SLi,Athlon64X2 6000+@3.2GHz, 2GB DDR2 XMS2, eVGA GF8800 GTS SSC 640MB, Intensity Pro 10-Bit HDMI Video, Creative XFi Fata1ity Plat.
TV TUNER CARD "ViXS PureTV-U 480B0 (NTSC/ATSC)" HP Desktops ?
By sonomablue in forum Capturing and VCRReplies: 3Last Post: 8th Apr 2022, 16:56 -
HD video from laptop to HDTV - "Clone" or "Single?
By mr-scarface in forum Software PlayingReplies: 1Last Post: 1st Jun 2009, 22:06 -
"DTV Nightlight Bill Becomes Law" - some USA analog after Feb 17
By edDV in forum Latest Video NewsReplies: 1Last Post: 25th Dec 2008, 18:18 -
Do hdtv owners use the "fill" mode to get rid of "underscan&
By yoda313 in forum PollsReplies: 20Last Post: 11th Jul 2008, 19:02 -
I'm unclear about the analog "pass through" to convert VHS to DV
By JediPM in forum Capturing and VCRReplies: 2Last Post: 23rd May 2008, 02:41
