Trying to put this desktop together, and I wanted to know if I'll have problems trying to install an ide dvd burner with a sata harddrive? In my diagram that comes with the dvd drive, they have both the dvd drive and the harddrive connected to the motherboard via an IDE cable? Should I be setting the DVD Driver as cable select, slave, or master. Thx very much!
Connect hdd on sata and have it boot up first in bios and dvd as master on the pata.
how many ide connections do you have on the motherboard? if you only have 1 then just connect the dvd burner to it and set to master. also set the jumper to master on the dvd burner. as for the sata hard drive it should be connected to the sata connector on the motherboard. there should be no problems as the ide dvd burner and sata hard drive will not be connected together on a cable.
IDE and SATA
By HotDamn! in forum DVD & Blu-ray RecordersReplies: 11Last Post: 6th Mar 2010, 01:49 -
sata vd ide
By dymx in forum ComputerReplies: 3Last Post: 9th Sep 2009, 09:04 -
Sata v.s IDE
By tapal in forum ComputerReplies: 4Last Post: 22nd May 2008, 06:04 -
SATA or IDE DVD writer
By m baqar in forum Authoring (DVD)Replies: 8Last Post: 28th Mar 2008, 19:35 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 21:15
