Whenever I insert a CD or DVD the icon corresponding to the CD or DVD drive in "MY COMPUTER" does not display the identifying label or graphics. How can I fix this? Thanks.
Either some virus has entered your system,corrupting it or it isn't supporting the drive.
The icon should stay the same, however, the drive name will usually reflect the label of the disc. Also, the label will often refresh the first time you put in a disc, but then upon swapping discs will return to the default or not change at all. This is been an ongoing issue with XP and none of the tips and tricks that I've used solve the problem. Regardless of the icon or name, it should not be affecting actual usage of the drive. This is just one of the annoying issues.
Google is your Friend -
The drive's label/graphics does not even refresh the first time I put the disc, neither when swapping discs. However, the discs are recognized by Windows,i.e., I can explore its contents via Windows Explorer or play them with whatever program I choose. I'm not sure if it's related to this issue,but I tried this fix below without success:
http://www.microsoft.com:80/downloads/details.aspx?FamilyID=c680a7b6-e8fa-45c4-a171-1b...displaylang=en -
I've seen other posts here and elsewhere concerning the same "problem". I haven't seen a fix to make it work correctly 100% of the time.
Well, I guess I'll have to live with it rather than having to fresh install Windows which is not justified for an issue which is not critical since as I said before Windows recognizes CD's and DVD's.
16:9 Material on a 4:3 DVD to be displayed on a 16:9 monitor
By willy4360 in forum EditingReplies: 5Last Post: 10th May 2010, 08:40 -
Question how to change icon of software icon
By jimdagys in forum ComputerReplies: 3Last Post: 10th Oct 2009, 05:47 -
DVD menu with an icon to link to a word doc?
By hbeasley1 in forum Authoring (DVD)Replies: 11Last Post: 29th Sep 2009, 10:13 -
dvd cover to icon
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2009, 12:21 -
Virtualbox - how do I add cd drive and graphics drivers?
By yoda313 in forum ComputerReplies: 3Last Post: 8th Mar 2008, 22:05
