I'm trying to convert some VOB files to MPG2 so I can edit them. After trying almost every method listed on this site and coming up with various audio sync errors, absent video, and so on, Simple File Joiner worked perfectly. The audio was in sync, the video was all present, etc...but the VLC-listed runtime for the video was 4:03. Despite that, the entire 2:56:50 of video played.
However, when I opened the file with Screenblast movie studio, it functioned as a 4:03 long video file with no audio track, and functions as only a 4:03 length video in all other programs I can think of to rebuild the MPG.
Is there a way I can fix this, and get this full video to function?
VOB2MPG was the first thing I used, but there was no audio in screenblast. I used AoA audio extractor, and the resultant mp3 had three billion different sync issues.
Rejig gives an unexpected end of archive error when I attempt to download it. I demuxed with DVD Decryptor, though, and got a working AC3 file, one working m2v file, and three m2v files that, when opened in VLC, just sat there doing nothing. -
It sounds like the source is a bit of a mess.
If you can get a working audio file from DVD Decrypter, and a working video file from VOB2MPG, you can either demux the mpg with Rejig (I use the version that installs with DVD Rebuilder) or just load the mpg and AC3 files separately into screenblast.Read my blog here.
Er...bump.
The best solution to this, so far as I can tell, is to somehow find a way to edit the SFJ file, despite its apparent 4:03 runtime. It's the only result I've managed to produce that is functional and in sync, so to get that on DVD would be great.
Other than that, is there a way I can fix the corrupt indexes, or resync the audio I have got?
VOB Wrong Length When Imported
By DebiKay in forum DVD RippingReplies: 3Last Post: 29th Apr 2012, 22:39 -
vob file has wrong length?
By Brainbanana in forum Video ConversionReplies: 16Last Post: 1st Mar 2012, 15:52 -
video conversion to mpg2/vob/h264..
By krohm in forum Video ConversionReplies: 14Last Post: 10th Jun 2009, 15:32 -
Vob File Length seems all wrong
By AlexHaden in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2008, 20:34 -
No video in VOB to AVI conversion
By Matt42 in forum DVD RippingReplies: 12Last Post: 24th Nov 2007, 22:04
