  1. I just downloaded a large MPEG, and when I try to play it using Windows Media Player, it says that the file is not supported. The only way it works is if I open it with Quicktime, which sucks. It won't open in Real Player or TMPEnc, so there is no way I can burn a VCD. Does anyone know if I need a codec or something? Has anyone run into this type of problem before? Thanks.
    it maybe is a mpeg2, just download the mpeg2 codec and try
    www.vcdhelp.com/vcdtools.htm#codecs
