Hi I am trying to covert a DivX Avi file but tmpgenc won't open the file whats wrong ? and also I am trying to convert a wmv file to mpeg 1 with tmpgenc but it freezes what should I do
Results 1 to 11 of 11
Hey,
I have the same problem too, and I see alot of previous post with the same prob. I hope you will find an answer to your prob. Maybe you can pop me a mail if you do!
Thanx!
tbachman@online.no -
Ok so many things to try - I'll just start listing them
for the DivX that won't open in TMPGEnc - first cover all your bases make sure you have all the codec's that might need installed. Try the krystal pack ftp://ftp.dvd-wizards.com/Vcdhelp2/kscodecsv433.zip
then go into TMPGEnc and make sure your Direct Show filter listed in the VFAPI plugins is set to priority of 0
then if it still doesn't open in TMPGEnc try to open it in VirtualDub - the error message in VirtualDub will usually tell you what your missing - if it does open in VirtualDub then just frameserve it from VirtualDub to TMPGEnc
as for the problem with the WMV - extract the audio to wav using dbPowerAmp http://admin.dbpoweramp.com/ --make sure you get the extra install for WMV -- then let TMPGEnc use the WMV as the video and the extracted wav file as the audio - that should fix the freezing
If you still have problems after following the above then - give us more details - such as what VirtualDub said when it wouldn't opent the AVI
I'd bet you will be a-ok if you try all the stuff I listedyour pal,
Stinky -
I got the dmpowerAMP music converter is that the wrong one becasue you can't open the wmv file with it it will only open wav and wave and cda
look around that site there is an extra download for wmv and asf support
your pal,
Stinky -
I don't get the part about letting tmpgenc mpg use the wmv as the video and then use the wav as the audio please explain.
After you extract the audio from the WMV - you will then have your original WMV file and a WAV file.
Open TMPGEnc - put the WMV in for your Video Source and then put the WAV in as your Audio Source
this way TMPGEnc only uses the WMV for the video conversion and we are hoping that the problem you were having converting it in TMPGEnc was in the audio stream - if that is true then the conversio should run just fine.your pal,
Stinky -
Ok the converting worked but the video freezes at 23 seconds the music keeps playing but the video freezes
I don't have anything more to suggest
not everything can be fixed - there is no fix program for bad WMV video streamsyour pal,
Stinky
Problem Converting AVI (DV) to MOV (DV)
By Casho in forum Video ConversionReplies: 3Last Post: 15th Feb 2011, 06:27 -
Converting from RM to AVI problem...
By Citrus in forum Newbie / General discussionsReplies: 3Last Post: 23rd Apr 2008, 18:19 -
Problem converting RM to AVI
By MJS in forum Video ConversionReplies: 9Last Post: 25th Oct 2007, 00:17 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22 -
Problem Converting AVI to xvid AVI (using AutoGK)
By foochuck in forum Newbie / General discussionsReplies: 2Last Post: 3rd Jul 2007, 10:57
